Cut a number of steel angles to fit inside short segments of Unistrut. Bolted a Unistrut segment to the vertical member of the cradle frame. Added aluminum sections of scrap rib material for spreaders to the Unistrut brace. One inch foam sheets glued to pad wing skins. Considering aluminum sheet caps with nutplates rather than foamboard to prevent entry and nesting by small animals.
