Install ruddervator hinge on starboard side stabilator. Initial hinge rivet holes were drilled centering the holes on the hidge rather than locating on center of knuckle as in plans. Second hidge set made from two shorter pieces and aligned correctly.
Stabilator tip cutout at 7/8" about 1/8" too much. Notched leading edge for instrument air port clearance.
