Dr. Pete's Xenos Build
Sonex XenosB
SNX-W01
Fit Wings Together on Ground
Fit the wings together on the grass to look at the alignment. Determined the spar ends need to be parallel and close for the main pins to fit. The rear spar drag tang is important for setting the spar alignment
Sonex XenosB Home
1277
Cockpit
25
43
Communications
Cowling
198
149
Finish
89
Hangar
60
261
Instrument Panel
49
76
Legal-FAA
Research
