Cut out 8 x 8.5" panel, bending 1/2" tabs on the 8" dimension to be used as a support between the instrument panel and sub panel. Will also provide real estate for mounting of fuse blocks. Needed additional trimming around panel angle bracket mounts to clear nutplates.
