Dr. Pete's Xenos Build
Sonex XenosB
XNB-L05
Brake Line Bulkhead Fittings
Drilled 3/8" holes for AN3 bulkhead fittings to pass the hydraulic brake lines through the cockpit. Used two washers to match the distance between engine mount angle and floor.
Pass through location
Fitting in place
Exterior location
Sonex XenosB Home
1277
Cockpit
25
43
Communications
Cowling
198
149
Finish
89
Hangar
60
261
Instrument Panel
49
76
Legal-FAA
Research
