Aligned and drilled foreward hinge half for rivets. Riveted hinge. When installing cowling, aligned and installed left and right vertical hinge pins then the bottomm Alignment very tight along the length. Fit resulted in a 1/8" movement at prop hub. Will remove one side of the bottom hinge rivets, re-align and rivet with cowl held by hub alignment block.
