Fit alignment spacer to prop hub. Initial trim using 1-1/4" dia holes within a diameter of the aft edge for landing gear clearance were not large or deep enough to accomodate engine mount. A 2" hole partially overlaping the first holes were deep enough but needed additial trimming on the inboard side with an angle grinder with a flap disc.
