Used 1/4" reamer to clear mounting bolt holes. Placed rear engine mount rubbers. Up drilled the Aerovee lifting hole to accomodate swivel shackle pin. Secured HF 500# rated chain hoist to ceiling beam. Lifted engine and manuvered fuselage closer to engine. Engine pitches forward when hoisted from the single point, used roller stand to help square the Aerovee mounts. Sprayed door and lock lubricant (wet/dry TFE lube) on rubber mounts to help move them into position when securing with AN4-35 bolts. Bolt threads bottomed, will try replacing with AN4-34.
