Brief Description: Install Fuel Line Bulkhead Fitting
Located and drilled firewall for installation of AN6 bulkhead fitting. Set 1/8" hole 12.25" up from bottom of firewall. Up drilled to 1/4", then used step drill for final 9/16" hole. Needs washer(s) to remove space for threaded nuts. Set fuel tank and began fitting for fuel line.
