Drilled 1/8" in pilot holes to 1/4" on drill press. Used Boelube as cutting fluid - melting a bit of the wax to the hot HSS-Co drill bit tip. Cut well. When half way through the bar, turned it 180 degrees and completed the hole from the back. Chamfered edge of holes. Reamed the hole to ensure round and straight.
