Brief Description: Starboard Wheelpant Cutout And Assembly
Used a 2-1/2" hole saw (larger than the 1-3/4" called for in the plans due to TOB flange) to set the top of the wheelpant mounting cutout. Cut two perpendicular verticals from wp cutout tangent with the hole and removed. Small filing to completely expose the TOB axle flange. Layout for hydraulic fitting clearence. Centered wheel and tire in wheel pant, marking outboard axles center. Drilled hole and installed screw with nut to hole outboard wheel pant in position. Will revisit the outboard attachement at a later time.
