Determined that locating the top threaded ports for hydaulic fluid bleeders would allow fluid from bottom to force air to the top port during fill. Also, the natural tendency of entrapped air to rise to bleeder is desirable. The port side brake fitting geometry differs from starboard, so two square openings were cut in the port side wheel pant mount plate top and bottom to allow 1/8" NPT brass elbow for both hydraulic and bleeder. The bleeder valve will be external to the wheel pant. The hydraulic line will enter from two 1/8" NPT elbows with a straight AN3 flare fitting aligned to gear leg.
