Fit forward vertical angles to forward tailwheel attach angle. Removed and re-riveted right side angle to allow it to lay flatter against the skin. Additional rivet place on right side.
If remaking this assembly, I would have drilled the bolt holes in the tailwheel mount and matched the forward attach angle rather than drilling the holes in the attach angle first.
