Attached aileron drive plate and ribs 1-3 with rivets at the trailing tips. Cut and drilled inboard and outboard hinges. Set hole spacing with aluminum ruler drilled on inch marks 1/4" from edge of ruler. Align drilled hinges to aileron, attached hinges with Clecos.
