Drilled attachent hole in titanium landing gear leg. Used a 1/8" cobalt pilot hole with melted Boelube stick as a cutting fluid. Inadvertently used a standard HSS bit in updrilling. The tip overhead and broke just as the point started to exit the pilot. Used a punch to remove the reminant. Completed hole with 1/4" HSS Co bit.
