Used a propane torch to remove the powder coating from the bearing ends of the rudder pedals. Fit the Delrin bearing blocks to the fuselage and align drilled the mounting holes. Weld-end of pedals tight against the bearing block.
To do:
Chamfer bearing blocks at ends A and C to relieve pressure points.
