Dr. Pete's Xenos Build
Sonex XenosB
XNB-C02
Finish First Rudder Pedal Block
When attempting to finish the second block, found that the paddle bit shaft had bent enough to wobble when starting to drill. Purchased a Forstner bit at HD to see if it will finish the 1" hole.
Step drill to 1 inch
Bent paddle drill damage
Paddle to clear 1 inch hole
Sonex XenosB Home
1277
Cockpit
25
43
Communications
Cowling
198
149
Finish
89
Hangar
60
261
Instrument Panel
49
76
Legal-FAA
Research
