Dr. Pete's Xenos Build
Sonex XenosB
XNS-T03
ST-1 Probe Mounts
Constructed and mounted ST-1 probe mounts for pitot and total energy probes.
Layout and bend aluminum mounts.
Probe diameter 1/2 inch
1/2 inch rivet tabs
1 inch probe mount
Test fit mount.
Prep rib tip and probe mount with medium sandpaper for epoxy 'bit'.
Mould aluminized epoxy into ribbons, embed probe mounts.
Compress mounting bracket to extrude epoxy.
Cleanup and rivet mount to rib.
Fit ST-1 probe brackets
Embeded in Al epoxy
ST-1 mount in tip ribs
Sonex XenosB Home
1277
Cockpit
25
43
Communications
Cowling
198
149
Finish
89
Hangar
60
261
Instrument Panel
49
76
Legal-FAA
Research
