David's RV-7
Date:  7-4-2008
Number of Hours:  8.00
Brief Description:  AHRS Mount
Had a nice big open space behind the flight displays that just seemed like the perfect place for the dual AHRS unit to be mounted. A great spot, but one thing that I don't want to do during future maintenace is lie head-first down in the foot well to do work.
Next I checked that I could fit the AHRS unit through the hole for the left display unit in the instrument panel. It did, so I decided to make a cutout in the instrument subpanel through which I could remove the AHRS if I needed to do maintenance.
I fabricated a dual-rail mount using two pieces of aluminum angle and fastened them to the forward bulkhead and to the back of the subpanel. I checked that the rail mount held the AHRS properly oriented to the aircraft axes. I fastened four nutplates to the AHRS and use screws through the bottom of the rail mount to secure it.
Maintenance access is through an opening in the instrument sub-panel, The opening is closed up by a two-piece cover which fastens to the subpanel. There are two holes with snap bushings through which the AHRS wiring passes.
mounting rails
mounting rails
access panel (removed)
general layout
general layout
