David's RV-7
Date:  1-29-2008
Number of Hours:  3.00
Brief Description:  Trim Servo Wiring
Worked from home today. Took the stick grip tops and all the stuff for them plus a servo, relay deck, and LED position indicator home so that I could figure out how it all went together.
Wired up the stick grips (see pic). There really wasn't a lot of room between the top section and the bottom section. The aft lead for the nose-up trim switch is very close to the bottom housing and I had a heck of a time soldering the lead onto it--mostly because my soldering skills are weak. I did improve as I went though. It took me an hour and a half to solder the first one and 20 minutes on the second one. Mostly because I wasn't happy with the results on the first one and kept doing it over again until I liked it.
I decided that getting it all rigged up on my breakfast bar was the best way to learn how to wire the airplane. So, after soldering the switches I wired in the relay deck (allows either stick to make trim inputs) and the servo motor. I also wired in the LED for indicating what the trim position is. Glad I did it this way--now I have a thorough understanding of how it all goes together. It'll be much easier to install it for real into the airplane.
Switch Wiring
Switch Wiring
Top of Pilot's Stick
Test Setup
Test Setup
