David's RV-7
Date:  1-26-2008
Number of Hours:  3.50
Brief Description:  Brake Lines (Rudder Pedals)
I received my new armored rubber hoses yesterday afternoon. I got Stratoflex 111 hose to replace the Parker plastic lines that came in the kit. I'm going to be putting in a nice interior so I didn't want cheapo-looking brake lines, plus I think the 111 lines will last longer/be less likely to leak on my carpeting.
So, with the hoses in hand I set about installing them. The attaching to the cylinders was pretty easy, but anchoring the mid-point was surprisingly a little more complicated. I had to first figure out where I wanted to mount it and then craft a mounting to hold the hoses firm. I made a little angle that has a nutplate riveted to it.
I finished up the installation and checked the athe hoses didn't bind or chafe anywhere through the full range of motion.
Lines Mounted
Lines Mounted
Adel Clamp Attach Point
Center Mount Installed
