David's RV-7
Date:  3-7-2008
Number of Hours:  6.50
Brief Description:  Pilot Stick Wiring
Played around for a while trying to figure out where the best location for the stick grip wires to exit the stick is. I tried running them straight out the bottom, but they touched the rod-end bearings for the aileron control tubes.
So, I decided to drill through the stick near the base in a location that ensured no interference or chaffing. I deburred it and inserted a nylon snap bushing through the hole from the inside. This I fastened to the stick with proseal and painted it to match when the proseal dried.
I fastened the stick grip terminal block and routed the wires to the terminal block and fastened them.
wiring passthrough
wiring passthrough
pilot stick
pilot stick
pilot stick installed
