Brief Description: Master and Starter Relay Mounts
Installed the starter and master relays onto the firewall today. Yeah! Nice to get working on the engine compartment finally.
Needed to fabricate a little doubler for the relays and rivet it to the firewall. I also drilled out some existing rivets and installed nutplates. The starter servo is installed upside-down so that when I'm doing acro in this little beast, the starter motor doesn't engage and munch off some flywheel teeth. ;-)
