David's RV-7
Date:  2-1-2008
Number of Hours:  0.50
Brief Description:  Center Tunnel Line Supports
Little job--made a couple foam supports to keep the brake and fuel lines from rubbing on the floor skin. This center channel is maybe 3/4 in high and will have the brake, fuel, and electrical wire running from the fuselage to the fron of the plane. It'll be under carpeting when everything is finished.
Foam Supports
Foam Supports
