David's RV-7
RV-7
Fuel Tank Attach Point (left)
Fabricated the inside bracket and shims for the left fuel tank attach point. Pretty easy, Pic1 (is after mastch drilling and priming).
Drilled out the rivets and got it all match drilled to the fuselage and installed the outer and inner brackets. Prett tame stuff...
Inner bracket, shims
Outer bracket
Orientation
RV-7 Home
1053
Firewall
