David's RV-7
Date:  1-12-2007
Number of Hours:  3.00
Brief Description:  Rudder Pedals Final Fitting
Finished up the fitting of the rudder pedal axles and the center support. Drilled holes for another mouning location that is 1" closer to the seats. I'm planning to mount the pedals in the most forward position and just use the seat as the adjusting point.
In picture 2 is a top down view of the pilot's rudder pedals. I mentioned before that the right pedal leans aft and the left one leans forward. You can see what I was talking about in the pic. SInce the pedal axles are fore and aft of each other, to have the pedals in alignment they need to be oriented this way.
Picture 3 shows the master cylinders attached to the pedal brackets. They had to be custom drilled because of the alignment differences (note above).
Now that everything is done, I'm going to take the pedals for powder coating. After that, the assembly will get set aside while I attach forewall goodies.
Center Support Fitted
Pedal Alignment
Pedal Alignment
Cylinders Fitted
Cylinders Fitted
