David's RV-7
Date:  3-31-2007
Brief Description:  VS Rear Spar and Rudder Install
Pic1 shows the lower VS rear spar after I drilled the pilot holes and one of the holes to full size. Once those were done, I was pretty much finished with the vert stab.
Itook Pic2 from behind the aircraft to show the whole assembly (minus the rudder at this point).
Pic 3 shows the VS installed and the rudder pinned into place. Tomorrow I'll adjust the hinge bearings and install the rudder stops.
