David's RV-7
Date:  6-26-2006
Number of Hours:  3.00
Manual Reference:  Sec. 6-11
Brief Description:  Trim Tab Assembly
Match-drilled, deburred, and dimpled trim tab skin, spar, and trim control horn. Machine countersunk the top surface of the spar.
Back-riveted spar to bottom of skin.
Completed trailing-edge bend.
Fabricated bending blocks and bent tabs on ends of skin. Match-drilled, deburred, dimpled and blind-riveted tabs.
