David's RV-7
Date:  4-20-2006
Number of Hours:  5.00
Manual Reference:  Sec. 6
Brief Description:  Build Rudder Skeleton
Fabricated R-917 shim. Radiused rudder horn to allow for proper fit with R-904 rib. Match drilled rudder skeleton assembly.
Match drilled spar reinforcement plates.
Fluted the counterbalance rib and rudder tip rib. Match drilled ribs and counter-balance skin.
