David's RV-7
RV-7
Sec. 6-11
Trim Tab Assembly
Match-drilled, deburred, and dimpled trim tab skin, spar, and trim control horn. Machine countersunk the top surface of the spar.
Back-riveted spar to bottom of skin.
Completed trailing-edge bend.
Fabricated bending blocks and bent tabs on ends of skin. Match-drilled, deburred, dimpled and blind-riveted tabs.
RV-7 Home
1053
Firewall
