David's RV-7
RV-7
Sec. 6
Rivet HS Rear Spar
Clecoed the Rear spar and reinforcing bars together and then riveted everything together. Riveted the elevator hinge brackets to the spar assembly. Bolted the 411 center bearing assembly to the spar, torqued the nuts, and applied torque seal paint.
RV-7 Home
1053
Firewall
