Finished prepping the HS-405 ribs. Since I'm waiting on my new HS-702s to arrive, I decided to start on the Vertical Stabilizer.
This is very easy so far compared to the HS. I prepped the ribs after I clecoed the Spar Doubler to the rear spar. Match drilled the hinges and doubler, ribs, and spars. Then I clecoed the VS skin to the frame. Tomorrow I'll match drill the skins.
