The flaperons went together very nicely. It's been nice to work with components that aren't so large as the wings. The skeletons went together first and then were fit to the lower half of the skin. Next will be to get the ratchet straps out again and fix the top of the skin to the skeleton.
Each flaperon is composed of an inboard and outboard section that are bolted together and off set such that the outboard section has 15-17mm of washout.
