Brief Description: Glued weather boot on windshield
Last two days we installed the weather boot on the windshield. Yesterday we glued it on, except for the curved corners, using 6800 adhesive. After letting it set for 24 hours we came back today and glued the curved corners using the same adhesive. We clamped it real good and will let it set for 24 hours. We then confirmed the aileron control limits and found some adjustment was needed. The passenger banana opening was conflicting with the fitting on the flaperon control arm. After widening the banana we are getting the correct amount of up airleron.
