Dean worked on fixing some of the issues we had with the engine start. Seems we had the backup battery and aux bus cb's crossed. Fixing that fixed the ECU/main fuel pump issue. He also discovered why the amp meter was not working--bad crimp. We still have the issue of the fuel pressure indication not working and need to determin if the fuel pressure regulator is ok. I worked on getting a solder sleeve on the passenger side ground sheath and putting a sub pin on it. Then I installed a back shell on the plug. Next, worked on attaching the passenger side flaperons with the appropriate bolts and washers. We insured the clearance with the wings per the plans.
