Brief Description: EGT probes and spark plug wires
Got a tip from Ray at UL to make drilling the exhaust tubes for the EGT probes go a lot faster. He suggested starting with a smaller drill bit like a size 40 and then up size to the 1/8". I did and went much faster. Drilled all four exhaust tubes and mounted the EGT probes. Next, started fabricating the spark plug wires. Going to use the passenger side as the exhaust side and labeled the cylinders. Cut the "3 cylinder spark plug wire and installed the plugs on both ends. Did same with cylinder "1.
