Doug's Web Site
Date:  2-12-2018
Number of Hours:  5.00
Brief Description:  Mounted CHT probes
I removed the baffles and did a little more filing to improve their fit. I also drilled the 20 size holes for rivets in the front and rear. The CHT fitting nub for the baylonet hit the cylinder head, so I ground it down so the fitting would thread into the cylinder. All four CHT probes are now installed. I sited the holes for the EGT probes according to Dynon instructions. The probe should be mounted between 2-8 inches from the cylinder head in a straight section of the exhaust tube. I found that 6" was good in all 4 exhaust tubes. Tried drilling the first 1/8" hole but my bit hardly dented the stainless exhaust tube. Dropped by Home Depot and got a better drill bit. Used some number 12 Adel clamps to finish mounting the oil pressure manifold. Started the mounting of the capacitor for the battery. Need another 32 Adel clamp.
CHT probes
CHT probes
Oil pressure sensor manifold
Capacitor
Capacitor
