Doug's Web Site
Date:  1-9-2019
Number of Hours:  4.00
Brief Description:  Trim plug and Rewired trim widgets
We have been working the trim indicator problem for the last couple of days. First, we noticed that one of the wires in the molex plug, for the stab trim, had popped out. So we decided to change the plug to a D sub instead of the molex. After doing this we found that our indicator problem still persisted, ie, when either the trim or flaps moved, the other indicator followed. We felt it was either a ground problem or that our trim and flap sensor wires were not on EMS pin 18, the 5volt wire. So we removed the Skyview and the map box which gave us excellent access to the wiring. We also hinged the instrument panel but did not use that option. Deano traced the wiring problem to the fact that our trim and flap sensor wires were not on the 5v wire. He corrected this and now the indicators are functioning correctly.
Ray Allen trim servo rewired with D sub.
