Dean continued to organize the wiring. We cut several pieces of 8 and 10 awg wire to connect he ExBus and the fuse panels and circuit breakers. I worked on installing the cabin heat flexible wires. First, I drilled holes from the upper flange of the console to the lower instrument panel bar. I installed clecoes and will rivet later. I ran the flexible snake and installed a 6 inch piece on the firewall to anchor the wire before connecting to the B nut on the heater butterfly valve.
