Dean came over and we got a lot accomplished. He wired a capacitor into the servo wires to counter noise as per Dynon's recommendation. Installed the ECU on the inside of the firewall. That required resiting the comm radio because the ECU has rubber feet and it sits further back. The comm radio was in the way so we put it on the bottom side of the shelf which required drilling out the nut plates. While Dean was rerouting some of the wires I got underneath and used some tie wraps to secure the GPS cable. We adjusted the elevator control tube to achieve the 28 +/- 2 degree up elevator and 18 +/-2 degree down elevator. We had shortened the control tube and the elevator control is now perfect.
