Doug's Web Site
Date:  6-6-2017
Number of Hours:  4.00
Brief Description:  Connected fuel and vent lines to Skytek
Unclecoed the rear channel cover on the pilot side to run the Skytek fuel sensor cable. Then I riveted the cover to the support and bolted the Skytek header to the support. With the Skytek tank in place I checked to make sure I could install the window without removing the tank. I can so I left the tank in place. I clamped the fuel and vent lines from the passenger side to the tank. I riveted an L angle for the tank closeout to the pilot side baggage floor.
Skytek tank
Skytek tank
Baggage floor with L angle
Window temporarily clecoed
