Doug's Web Site
Date:  8-26-2017
Number of Hours:  3.50
Brief Description:  Covered console with carbon fiber vinyl
While we were getting heavy rain from hurricane Harvey I decided to work on the plane. When we temporarily installed the instrument panel a couple of areas needed to be trimmed. I trimmed the L angle flange on the pilot avionics shelf so we can mount the arms under the instrument panel support rod. This will give clearance to a couple of switches that need some room. Also trimmed two L angles around the fuse panels that are conflicting with the map box. I covered the console with black carbon fiber vinyl and started to install the components. Need to wire the headset and phone jacks and will hold off on installing the cabin heat cables and parking brake cable.
Modified the pilot shelf
Covering the console
Installing components
