Doug's Web Site
Date:  5-20-2017
Number of Hours:  4.50
Brief Description:  Avionics shelf
Worked on right half of the avionics shelf. It is a 12" x 19" piece with a couple of L angles. I cut a trap door in it because we will have a couple of fuse blocks in addition to the EXBus II panel. The fuse blocks will be mounted on the trap door for easy fuse replacement. On this shelf we will install the EXBus II, fuse blocks, relays, diode, and the backup battery for the Skyview panel.
Shelf cutout
Shelf cutout
Hinge on shelf
Hinge on shelf
Shelf and L angles
Shelf and L angles
