Doug's Web Site
Date:  6-8-2018
Number of Hours:  3.00
Brief Description:  Filed pilot side flaperon arms
Found that the pilot side flaperon was rubbing on the flaperon arm. Took the flaperons off and filed the arms. No rubbing now. Reassembled. Attempted to tap the inboard mass weight to 6-32 but the tap broke. That is the second one to break in the steel weights. So, guess I will have to epoxy the pvc covers for the mass weight. I wanted to secure these with screws as I might have to take them off in the future to adjust for painting. But epoxy will work if I only apply it at the rear of the covers so I can remove it if need be.
