Dean and I used a long level to locate the neutral point of the flaperons. We used the outboard flaperons and then marked the neutral point on the fuselage. We removed the inboard flaperon and then drilled the hole for the pivot pin. After drilling all the holes we then riveted it in place and then reinstalled the flaperon. All the flaperons were balanced and bolts were tightened.
