Doug's Web Site
Date:  6-10-2017
Number of Hours:  5.00
Brief Description:  Torque tube end plate
Installed the Andair one way check valve in the return line to the Skytek header tank. Cut an L angle support for the lower baggage floor. Before I clamp the fuel line and return line to the Skytek I switched gears and built the torque tube end plate support. Since the access port is open it is easier to build the torque tube support now. The end plate angle and end plate had to be trimmed but otherwise it was straightforward. It is now done except for drilling the gussett holes in the z channel of the access port.
One way check valve in return line
Steel end plate trimmed
Torque tube end plate gussets,  and angle
