Brief Description: Trimmed the carpet, worked on the instrument panel
Took the carpet that we had worked on and improved. Laid it on some new carpet and cut it out. Once in the aircraft I trimmed in several areas to improve fit. It is almost ready for glueing. I cut a hole in the pax flaperon cover for a USB port. Dean trimmed the end pieces of the instrument panel that were printed. We drilled the holes in the panel for the pieces. We fit the ELT panel and drilled its holes. We riveted the instrument panel to the cage and then dropped it on its hinge. The area behind the panel and the avionics bays are fully accessible. Dean started to hook up some wires.
