Doug's Web Site
Date:  9-3-2017
Number of Hours:  4.00
Brief Description:  Constructed template for carpet
Removed the map box and covered the last third of it with carbon vinyl fiber. This is to insulate it in case a wire comes loose and touches it. Just a precaution. Got some brown paper for a carpet template. Obtained the measurement of the baggage area and floor. Plan to glue the carpet to the baggage shelf, and floor aft of the inspection plates. In these areas I will use carpet tape to provide access to the inspection plates. Cut the template out and then fit to aircraft. Trimmed several areas and taped in place.
Vinyl on map box
Vinyl on map box
Cutting out carpet template
Laying out template
Laying out template
