Brief Description: Installed NACA vents with Chemseal
Used Chemseal to coat the lip of the NACA vents. Will let it sit for 3 days or so and then rivet. The Chemseal is an adhesive sealant. Installed the fuel sensor on the Skytek header tank and then applied a generous quantity of Chemseal around the nut and wires.
