I gathered all the door components and prepped them for installation. Drew centerlines, drilled pilot holes, deburred and readied for the doors. I cut the 5052 1/2" fuel and vent tubes and used my tube bender to bend the ends 90 degrees. Will need to bead the ends that connect with rubber fuel hose to the Skytek header tank. Need to shorten the piece that supports the fuel shutoff valve from the right wing.
